Like everyone else said, depends on manufacturer.
Most engines do not require premium. Most Euro gas engines do, although there is an attempt today by VW to allow 87-93 octane rating. However, they state that peak power is lost.
Mazda in CX-9 explained it best. If you use regular engine makes 227hp and 310lb-ft. If you use premium, engine makes 250hp and 310lb-ft. So benefit is in high rpm. Now, most American buyers buy HP, but actually they love torque. So Mazda basically said: yeah, in CX-9 soccer moms will mostly use low-mid range rpm, so why bothering with premium if you do not use high rpm. If you do (and most drivers of CX-9 do not) then just put premium.
Now some manufacturers are pretty strict on that and BMW, MB and some others are pretty strict on minimum 91.
