Yet another M1 0W-20 grade flavor!
by fdcg27
02/25/18 07:40 PM
The Winter Olympics
by BlueOvalFitter
02/25/18 07:23 PM
Enchilada casserole
by car51
02/25/18 07:21 PM
John Force Crashes at Phoenix!
by KneeGrinder
02/25/18 07:11 PM
Need floor jack that can use Pinch Weld adaptor
by MI_Roger
02/25/18 07:10 PM
The new Champ ST9688 is fat like the 3593
by slacktide_bitog
02/25/18 07:10 PM
Do you drink milk regularly?
by Reddy45
02/25/18 07:05 PM
What Is This Symbol?
by BlueOvalFitter
02/25/18 05:29 PM
Can't believe I fixed it
by Stelth
02/25/18 04:40 PM
Cruise Control Set at 55
by das_peikko
02/25/18 04:39 PM
Who here has satellite radio in your vehicle?
by ZZman
02/25/18 04:01 PM
Oil choice for new to me 07 escape V6
by gabriel9766
02/25/18 03:10 PM
Super cleaning windshield
by mclasser
02/25/18 02:36 PM
New WM oil filters...
by rollinpete
02/25/18 01:49 PM
Swapped Out Bunch of Indoor Flood Bulbs to LED ...
by LoneRanger
02/25/18 01:45 PM
Scanner ABS Transmission and Engine Codes reader.
by littleant
02/25/18 01:38 PM
Meijer - Quaker State buy one, get one 50% off
by Bighorn2500
02/25/18 12:50 PM
Anyone own a 3rd generation Toyota Tacoma
by 007
02/25/18 12:47 PM
Best "wax as you dry" type spray wax?
by aquariuscsm
02/25/18 12:39 PM
Any current Edge 0W20 users here ?
by aquariuscsm
02/25/18 12:27 PM
A1ex, Grozd, swc, coronad0, davidsain
64288 Registered Users
114 registered (andyd, antonmnster, AV8R430, asiancivicmaniac, 2015_PSD, 901Memphis, 12 invisible), 1754 Guests and 95 Spiders online.
64288 Members
65 Forums
278797 Topics
#4461378 - 07/17/17 03:19 AM Usage of mothballs - long term effects?
SnowDrifter Offline
Loc: WA
I use mothballs to keep the critters out from under my hood and around the car. Just wondering if the material in it - naphthalene - would cause any harm to the plastic bits or wiring long term?
I couldn't find anything one way or another
#4461381 - 07/17/17 03:53 AM Re: Usage of mothballs - long term effects? [Re: SnowDrifter]
Brad_C Offline
Loc: Perth, Western Australia
I wouldn't have thought so. My pool electronics have always had naphthalene in them and after 15 years the guts are still as good as new. I had to replace a worn microswitch in a timer recently and I was floored at the condition of my chlorinator which sits outside in the weather and exposed to all sorts of vermin. No insect ingress and all cabling and plastics were as good as new.
There are always potential minor material compatibility issues, and there are certainly a larger variety of under bonnet materials than found in an electronic appliance, so ymmv.
#4461386 - 07/17/17 04:30 AM Re: Usage of mothballs - long term effects? [Re: SnowDrifter]
Lubener Offline
Loc: N.Ohio
I use mothballs effectively every winter in my stored vehicles and remove them when driving resumes. If there are any effects, it has to be better than a rodent building nests or chewing on wiring harnesses.
Edited by Lubener (07/17/17 04:30 AM)
The "thinking" man's friend.
#4461414 - 07/17/17 06:04 AM Re: Usage of mothballs - long term effects? [Re: SnowDrifter]
Kestas Online   content
Loc: The Motor City
I understood mothballs may discolor vinyl and other plastics, so I loosely wrap them in a paper towel.
#4461426 - 07/17/17 06:37 AM Re: Usage of mothballs - long term effects? [Re: SnowDrifter]
Eddie Offline
Loc: Florida, Cape Coral
I keep them in my tool box to prevent rusting.
CX5 Touring 2.5L :-)
#4461429 - 07/17/17 06:39 AM Re: Usage of mothballs - long term effects? [Re: SnowDrifter]
bioburner Offline
Loc: Minnesota
I have a homestead in the middle of either corn or bean fields and rodents are a major issue. Have used moth balls for decades and have seen no issues. I found some that even come in small sachets are great for in car use. Late fall a sprinkling of flakes around building helps deter the vermin.
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
#4462044 - 07/17/17 04:44 PM Re: Usage of mothballs - long term effects? [Re: SnowDrifter]
69GTX Offline
Loc: Connecticut
Scented dryer sheets seem to work pretty good for me. They smell a lot better than moth balls.
2002 Lincoln Cont 4.6L DOHC/ 78K mi /PPlat 5w30/FUG XG2
1969 Ply GTX/RRs
