Originally Posted By: i_hate_autofraud
Did you have any shift issues?
Could you change the tranny filter?
No issues at all . Car had ~ 30000 miles on it at the time .
No , I did not change the filter . From what I read , that requires you to pull the transmission and split the 2 case halves ? Not a DIY procedure , at least for an old fat man .
Here is part of my thought process . I figure any mechanical device such as a transmission or engine is going to experience accelerated wear at the initial " break in " process ( first 5 , 10 , 15 thousand miles ? ) . Due to " burrs " and slight roughness of parts moving against each other . Since I can not replace the filter DIY , I am hoping an early drain & re-fill will help prevent these " wear participial " from getting locked away in the filter . Is this a correct plan / procedure / thought process ? I do not know .
I plan to do an engine oil / filter change in the next few days . Thinking of doing another ATF drain & fill . Since the 1st one replaced , maybe , 1/2 the total amount of fluid . ( Considering the fluid in the torque converter , that does not drain out ) . It has been 4000 - 6000 miles since the previous drain & fill .
By the way , this transmission does not have a dip stick . :-(
Thumbs down for GM ! :-(
Thanks ,
God bless
Wyr
