Originally Posted By: ARCOgraphite
#5 NGK is VERY HOT is that the spec? Some corona on the porcelain, and some bluing on the shell. Clean burn, but why a HR 5
Yes, 5 is in fact the stock heat range.
The OE spark plug is the NGK PFR5G-11 (Laser Platinum, double platinum) also listed in parts store catalogs as NGK 2647
However, Nissan also gives alternative options one heat range above or below. As you'd guess, PFR4G-11 and PFR6G-11
But since the OE NGK Laser Platinums are $9/each, I decided to use Denso iridium #3395 on my 96 I30. However, the Denso double platinum #3264 would also work well in these cars.
NGK also lists the iridium #7994 IFR5E-11 as ok to use. These actually cost less than the NGK OE platinum plugs, and they'll last longer, too.
