Originally Posted By: Triple_Se7en
Zee
Filter media on the move can disrupt / displace something that's stuck to it prior.
If you could live inside an oil filter, I'm sure you'd see the media moving/flexing a little bit all the time due to normal pressure pulses going on from the PD oil pump, and the changing delta-p across the media. So that means all are susceptible to this, if it actually happens.
Zee
