Thanks everyone for the input. It has not thrown any codes and runs just fine. I was just wondering about the timing chain because some engines are known for breaking timing chains, but I never heard anything negative about the Chevy 3.4
It has had the intake gasket done twice. The first time was under warranty with the first revision of that gasket. That failed and the second time it was done with the second revision of that gasket.
The cooling system has been flushed twice over the years, and the radiator sprang a leak a couple of months ago so it has a new radiator and some new coolant even though the coolant that was in it was not that old.
The brake lines rusted out and sprang a leak and were replaced with nickel alloy lines, along with new fuel lines. That was not cheap. Chevy no longer caries either. The pre-bent fuel line had to be imported from Canada, and the brake lines had to be bent to fit.
The trany fluid and filter was replaced twice so far, and a trany fluid cooler has been added.
