Is it OK to blend the older CJ-4 with the newer CK-4 or would you guys try to stick with just one? Specifically talking about blending 2 gallons T6 CJ-4 with 3 quarts T6 CK-4 in a newer engine with DPF.
Personally I wouldn't worry about. Oils are formulated to mix without problems.
