Originally Posted By: aquariuscsm
The ones who remove the oil filter,drain it,and reinstall it. How do you do that without damaging the case? Plus doesn't oil drain all over the filter,making it too slippery to be able to reinstall and properly tighten it,even if you clean it up really well? That just seems like a huge pita to me.
Avoiding damaging the case is very easy, if it wasn't overtightened. I do admit I once ruined a filter I'd planned to reuse, by whacking it on the dome end too hard. That distorted the internal leaf spring, causing the internal components to be loose enough to rattle when shaken. (I hit them that way so air could enter through the anti-drainback valve, to allow more used oil to drain out.)
Avoiding spilling oil "all over the filter, making it too slippery" was also easy.
