Hello. I am getting along pretty fine in my truck even though it the AC isn't working. It is not my daily driver, but had AC but it began shaking violently at times, so I removed the belt and tension (it is cool and a rarity that I could do this as many cars seem to have everything incorporated into a single serpentine belt). Anyway, it is big money to fix it and I am kind of a bare bones guy with some things, so I am thinking of eliminating the heat exchanger that is in front of the radiator ( I think you call it the coils, evaporator or condenser I don't know HVAC too well).
Anyway, GENERALLY, would deleting this heat exchanger IMPROVE the work the radiator can do?????? It seems to me that the blast of air from in front of the car that is going through the grill would greatly make the radiator and the engine cooling system more efficient, have a high capacity, and make life easier on everything else under the hood.
But I could be wrong and maybe the AC's radiator and the engine's radiator are made to work TOGETHER and somehow push/pull and pressure and move air away and out (or something).
MORE SPECIFICALLY, I wonder this on my 6.0 V8 Chevrolet 2500 and on third generation Camaros (305s).
Does the AC system hinder or improve the radiator's ability to dispatch heat?
I am much more concerned with heat, mainly since I live in the south, but another consideration would be in cooler months that it could remove TOO much heat like you see the BIG RIGS with Wreaths and covers to assist with that.
Thank You.
Joseph
Thank You.
Joseph
