Just got an email from Chevy stating that we have a Stochastic Pre-Ignition (SPI) Causing Cracked Piston recall.
Program Description:
Certain 2016 and 2017 model year Chevrolet Malibu vehicles equipped with a 1.5L LFV engine may have a pre-ignition condition that could cause piston damage. If this condition occurs, the vehicle may perform poorly and oil consumption could increase. In addition, a service engine light may illuminate indicating an engine misfire. If the condition is present, and the repair below is not completed before multiple pre-ignition events occur, a piston may be damaged and the engine may need to be repaired or replaced.
Repair Description:
Reprogram the Engine Control Module (ECM) and change the engine oil with ACDelco dexos 1 Full-Synthetic motor oil of the part number as indicated in the parts section. (In Canada use the exact Mobil 1 part number specified in the parts section). It is very important that only oil with the correct part number is used in this repair.
Interesting that they now require a synthetic oil for this engine because of this recall. And that only the oil with the correct part number be used. Why would that be?
And Darn it! I just did my own oil change oil with M1 EP. Now they want to drain it out.
Repair Description:
