Originally Posted By: ZeeOSix
What makes the bearing fail is loss of proper oil film thickness due to the viscosity getting too low from increased heat - regardless if the the oil pressure is normal or low. Lower oil pressure due to hotter oil (with PD pump) doesn't mean there is a lack of flow, it's just an indication of less flow resistance due to the hotter/thinner oil. The same volume of oil is being pumped (less any slight increased pump slippage due to thinner oil) ... it just takes less pressure to push that same positive volume output through the oiling system.
https://youtu.be/ASAdkJydBFU?t=8m30s
I guess you could say that if you're running a car real hard for long periods on the track, and the oil pressure gets extremely low (compared to what it is with normal street driving), that's an indication the oil is becoming very thin due to heat, and it's an
early warning sign that you're probably close to loosing a safe oil film thickness in the bearings.
Yet at t=7:33 he talks about using 0W-20 in a 4 hr track session and getting the oil to 270 F. Then doing a UOA at 4000 miles, and the oil was just fine and didn't show any signs of wear metals. So I guess he concluded the bearings survived just fine on 0W-20 at 270 F in that particular track session. Could be, but wonder how close he was to chewing up some bearings ... ?
https://youtu.be/ASAdkJydBFU?t=7m33s
.....I agree....
That's the key point in the "thick/thin" issue, in that when you are in hydrodynamic lubrication (and bearings should be), it doesn't matter how thick the oil film is, the protection is there...nothing touches.
Redline 0w20 has an HTHS of 2.9 which should also be considered. It's the same as an ILSAC 30....TGMO at 2.6, and one of them (there are multiple), CATERHAM tested dropped to 2.4 inside a few hundred miles may well have had a different outcome.
The thinner stuff has lower "headroom", safety margin, whatever...and even with UOA, you won't know exactly how much margin that you have, until you don't.
May well be fine, until you pick up some leaves or a bag, and you need that safety margin.
