Thanks for the link to the Argonne Study. I cannot comment on the Archoil product that you are using, but the use of boron to promote a more durable poly-borophosphate tribofilm is also reported in the SAE paper #2016-01-2276, affiliated with Toyota, so there is a good possibility that this technology has merit. If you read the abstract and preview of the SAE paper, you also get an idea of the complexity of the interactions between different antiwear and antifriction additives. This is why I do not use any after market additives with fully formulated motor oil.
