My new trans pans have drain plugs.
On the Explorer I reinstalled the bar magnet. It was coated with a black residue that looked like laser printer toner. About 30K miles since it was last touched, it wasn't really thick but it was there. It was slightly coating the old pan too. There was no real metal to speak about (unless those particles are metallic).
I have new pans for my other cars, replacing due to corrosion, I'm wondering if I should get magnetic bolts ( I think they are 14 X1.5)?
AND
should I leave the old magnet in the pan. I'm thinking if the original magnet isn't there and you have a plug magnet there is no need to drop the pan?
Honestly I don't mind so much dropping the pan if the fluid is out, but it may be unnecessary work. The 20 bucks for that pan is more than worth it to me not to get a fluid shower(don't like the idea of running the cooler close to dry on an old transmission), and considering places now want almost 300$ for a total trans service its a no-brainier. (some dealers close to the 400 mark!, A stupid flush is 225, and 150 for the pan).
I know some cars come with oil pan plug magnets for the engine (or you can add it).
AND
