Worn cam lobe symptoms
by NICAT
12 minutes 53 seconds ago
White car..has white grease
by Vdubuk
15 minutes 4 seconds ago
Do you need to change oil if your engine leaks
by Vdubuk
57 minutes 12 seconds ago
Castrol Edge 5w30 A3/B4 SCA sale 23-24 April $29
by KL31
Yesterday at 10:50 PM
Testing the "oil goes bad with age" theory
by Atomic
Yesterday at 09:12 PM
08 Grand Caravan with 156k. ignition problem
by Mark72
DexOS in a 2005 Cavalier LS?
by GMWeber
Yesterday at 09:10 PM
US-Canada mail transit questions..
by earlyre
hybrid ICE wear
by tigrpal
Yesterday at 08:51 PM
03' 2.3 Ford Focus / Dash light on steadly
by Oregoonian
Yesterday at 08:47 PM
Tundra vibration
by pda1122
Yesterday at 08:39 PM
Who says Corvettes are gas guzzlers?
by Patman
Yesterday at 08:26 PM
Mobile rebate question
by Snowball
Yesterday at 08:25 PM
Oil shear and 0w,5w,10w?
by Camprunner
Yesterday at 05:42 PM
Looks like the Jeep needs axle bearings
by Nick1994
Yesterday at 05:13 PM
Toyota OEM Cartridge Filter, Cut Open 12,669 Miles
by Nick1994
Yesterday at 04:53 PM
S/C Range Rover, 5000kms 33 different oils UOA
by Vladiator
Yesterday at 04:24 PM
Buying oil on price - Pricing Rant
by JHZR2
Yesterday at 04:22 PM
Mix of 33 oils VOA
by Vladiator
Yesterday at 04:19 PM
Sugar Binge Hangover ... :~/
by LoneRanger
Yesterday at 04:18 PM
daylateetc, Kjammer, sonnyk, PWMDMD, usernameunknown
64820 Registered Users
16 registered (FowVay, ctechbob, Duke, michaelluscher, edyvw, Billbert, 3 invisible), 639 Guests and 48 Spiders online.
64820 Members
68 Forums
282164 Topics
#4294443 - 01/05/17 07:54 PM 2002 Ford Crown Victoria 195k, 5.2 on Maxlife 5W20
Colt45ws Offline
Loc: Central Washington
Previous UOA
Since I put this oil in Ive gotten regular work and have been putting about 12 miles/day on it, and sometimes 500 on a weekend. My daily drive is all rural backroads with 50mph limit, but a few stop signs. My weekend getaways are obviously all highway. I have a block heater and have been using it religiously. I almost never idle to warm, maybe twice in the past month.
Length of time in service on the oil is was 5,250 miles, 3 1/2 months. Miles on the car is 194,750. (I planned it this way so my next change is at 200,000.)
Length of time in service on the oil filter is 12,750 miles, 6 1/2 months. It was left on again and will be changed at 200k with the oil.
Top up was 1 quart at about the 4.5k mile mark.
Still using Lubeguard Biotech oil treatment at 3oz/qt
This fill marks the transition to Maxlife Syn. Two quarts and what was left in the filter were blend, and the remaining was Syn along with the top up.
Oil filter is a Fram XG2
Code:
Iron		22
Chromium	1
Nickel		2
Aluminium	27
Copper		5
Lead		0
Tin		0
Silicon		18
Sodium		334
Potassium	3
Titanium	0
Molybdenum	201
Boron		10
Magnesium	2
Calcium		2193
Phosphorous	915
Zinc		747
Fuel		<1 - Estimated
Soot		<.1
Water		<.1 - FTIR
Visc		[email protected]
TBN		4.37
Oxid		20
Nitr		12
Lab is OAI/Polaris
In the previous UOA there was discussion about the Al reading 19ppm with 7500 miles and now its 27 with 5250 so it is defiantly accumulating faster. Not sure why. The timing chains were discussed and thats a definite possibility. At the moment, the engine is quiet, so Im not going to do anything beyond drive to the next oil change. At that point I will have another UOA done and also cut open the oil filter.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 75k
Castrol EDGE HM 5W30, Fram XG2
#4294451 - 01/05/17 08:09 PM Re: 2002 Ford Crown Victoria 195k, 5.2 on Maxlife 5W20 [Re: Colt45ws]
DoubleWasp Offline
Loc: Fort Lauderdale, FL
Hrm. What's with the Sil? Done any work lately? Air filter?
#4294456 - 01/05/17 08:16 PM Re: 2002 Ford Crown Victoria 195k, 5.2 on Maxlife 5W20 [Re: Colt45ws]
zeng Offline
Loc: Malaysia
Ever consider switching from xW20 to thicker viscosity grades ?
#4294461 - 01/05/17 08:22 PM Re: 2002 Ford Crown Victoria 195k, 5.2 on Maxlife 5W20 [Re: DoubleWasp]
Colt45ws Offline
Si is on the decrease after I drove it 160 miles with no spark plug in the #5 hole. It was sucking dirt in and sanding the rings. You could see this because chromium was 5 and Si was 51 at the 175k change this occured during.
Im thinking about going 5W30 Maxlife on the next change, but I doubt it will affect anything either way.
Edited by Colt45ws (01/05/17 08:23 PM)
-Colton
#4294481 - 01/05/17 08:50 PM Re: 2002 Ford Crown Victoria 195k, 5.2 on Maxlife 5W20 [Re: zeng]
69GTX Offline
Loc: Connecticut
I would as you already have 1 qt of makeup during an OCI. That engine was originally designed for 5w-30 and only back specced to 5w-20 in 2001. Made the leap in my 2002 4.6L in 2015. And I experienced about a 1qt loss on 5w-20 synthetic, a lot less on 5w-20 conventional....and nothing on 5w-30 PP.
2002 Lincoln Cont 4.6L DOHC/ 81K mi /PPlat 5w30/FUG XG2
1969 Ply GTX/RRs
#4294508 - 01/05/17 09:29 PM Re: 2002 Ford Crown Victoria 195k, 5.2 on Maxlife 5W20 [Re: Colt45ws]
Y_K Offline
Loc: WA (USA)
You can use this for comparison, didn't want to create a new thread. This is my regular mix of M1 0W-40 : M1 0W-20 EP = 4 : 3 which I presented to the lab as a mix of leftovers, just to see how they cope with it:
plus 6 hrs of idle time for this run; regular MC 820S filter
#4294922 - 01/06/17 11:41 AM Re: 2002 Ford Crown Victoria 195k, 5.2 on Maxlife 5W20 [Re: Colt45ws]
69GTX Offline
Loc: Connecticut
Interesting mix Y.K. of Mobil 1 oils. The net combination of those 2 gives a decent dose of every major additive except titanium and sodium. This seems to work very well for you. I have to wonder why none of the oil formulators or suppliers sell such an oil in this weighting? Mobil 1 has nothing like this in a single package.
1969 Ply GTX/RRs
#4294940 - 01/06/17 11:56 AM Re: 2002 Ford Crown Victoria 195k, 5.2 on Maxlife 5W20 [Re: 69GTX]
Y_K Offline
Loc: WA (USA)
I would guess, it may be in the way of official certs, and the market for this kind of concoction may be limited.
I am happy with my metal numbers..
#4295283 - 01/06/17 07:53 PM Re: 2002 Ford Crown Victoria 195k, 5.2 on Maxlife 5W20 [Re: 69GTX]
Colt45ws Offline
The loss was 2 quarts per OCI before I started using Lubeguard.
It wont magic pill my wear numbers but Ill switch to 5W30 next OCI.
-Colton
#4295539 - 01/07/17 08:10 AM Re: 2002 Ford Crown Victoria 195k, 5.2 on Maxlife 5W20 [Re: Colt45ws]
KCJeep Offline
Loc: Mahzurrah!
Jump up to a good 30 grade and watch that aluminum ppm drop like a rock. Have seen the same thing in Hyundai/KIA's and Jeeps.
04 Jeep Grand Cherokee 4.0 147k - GTX 5w30/10w40
09 Lincoln MKZ AWD 89k - Magnatec 5w30
12 KIA Sedona 83k - Edge 0w40
09 Ford Focus 127k - GTX UC 5w30
#4295792 - 01/07/17 12:56 PM Re: 2002 Ford Crown Victoria 195k, 5.2 on Maxlife 5W20 [Re: Colt45ws]
Y_K Offline
Loc: WA (USA)
As for the potential chain guide issue, those are there for another good 30-40k miles after you start hearing the real racket there - so you can procure replacement parts with prudent reserve smile
#4296252 - 01/07/17 09:08 PM Re: 2002 Ford Crown Victoria 195k, 5.2 on Maxlife 5W20 [Re: Colt45ws]
Colt45ws Offline
If it is the timing chains, Imma just put my spare longblock in it.
-Colton
