Liking Castrol 5W-50 Syntec in R1200R BMW So far
Ruidoso, NM USA
Last few OCI my 2011 BMW R1200R had VR-1 mixed to approx 15W-40. Analysis has been great but on cool (50F) the bike would often stall on first start with the VR-1. Now with the 5W-50 it is good to go on cool mornings with never a stumble.
Now at 2500 miles on the Castrol and will send a sample @ 5000 when I change oil and filter. I expect shear to a 40wt is possible, but that is within spec and equal to my prior use with good result. Crankcase Oil does not lube the gearbox or clutch.
I'm looking forward to seeing this. I've used this oil in my car a few times and it's really smooth,cold or hot. If it was more readily available I'd use it and it only. I don't think I've ever seen a UOA on it,car or bike.
