Its well known in here that I stick as close as I can to use the recommended oil in my 2014 Road King as required by Harley Davidson.
The thinking is, simply, no different then any other car, truck, boat or piston aircraft. I use the recommended fluids, but for some reason, its the Wild West with motorcycles and I suspect the reason is, that they are more of a toy for some people, then a serious piece of machinery.
Anyway, its known in here that I use an HDEO in my 14 Road King, Mystik JT8 semi-syn 15/50 has performed perfectly for over 20,000 miles now with multiple terrific UOAs posted in here. Harley only recommends their own oil, yet as an emergency if not available an HDEO of CH4+ or higher is acceptable, even though it says change back to HD oil, I simply use an HDEO full time.
I had an 8 gallon supply of JT8 and I also use it in my boat, the supply was getting low this spring and I saved what I had so I would know I had enough for the boat oil change as it is a mail order item. I also thought this was the ideal time to test out a theory as I have seen people swear up and down in some motorcycle forums that engine oil will run cooler if it is a full synthetic. I can even say that I myself could see some reasoning in that, at the same time, I was not looking to change oils but just a fun test.
So for the heck of it I purchased a 5 quart container of Mobil 1 15w50 full synthetic that only claims an outdated HDEO rating of CF on its website, its not even on the container anymore. But at least, in my mind, it was something better then maybe running a gasoline only "S" rated motor oil.
I know the oil temperature that my Road King runs at like the back of my hand, temperature is indicated by a Harley Davidson Oil Temperature Digital Dipstick, the sensor is always submerged in the oil pan.
Harley lists normal oil temperature of 230 degrees in the shop manual for the 2014 touring bikes.
Mystik JT8 15w50 -
Typical summer time temperatures of 87 to 100 degrees, 2 up, 80 MPH interstate for approx 100 miles will always produce the highest oils temperatures, even though at these speeds the highest amount of air is being rammed through the oil cooler, the typical oil temperature will run 249 to 257 degrees.
Stuck in beach traffic about 2 miles right before the beach produced the highest temperatures I ever saw on the bike one summer of 267 degrees. I since installed a Lenale engine fan for those VERY rare times I am in beach traffic. The fan does stabilize and reduce indirectly through engine cooling the oil temperature by a few degrees when turned on.
Ok, so my test of the oil below on 6/27/20, same run to the beach, temps could have been a bit warmer in the morning but overall pretty much the same conditions experienced over the last 5 YEARS with the Mystik JT8 on this run.
Mobil 1 15w50
There maybe something to what others have posted on full synthetic runs cooler or maybe not, there is a difference, however slight, I am not so sure it is in a margin of error but I have done this run so many times with the JT8, at the same time this is the only time with the Mobil 1 but I feel confident to say the oil will run, however insignificant slightly cooler with the Mobile 1 over the Semi Syn JT8 by about 1 to 2% and why I say insignificant, maybe that difference would be greater if JT8 was a full conventional.
Results with the Mobile 1 15w50
Same conditions, 2 up, 80 MPH, interstate for approx 100 miles morning temps 85 or so degrees warmer by the time we got there.
Oil temperature to the beach ran 247 degrees.
Oil temperature on the return trip 251 degrees. (oil temp on the return trip is always hotter due to it being the hottest part of the day 90+ degrees)
It is premature to say this, but I feel comfortable to say, oil temperatures with the Mobil 1 15w50 will most likely result in a 1 to 2% reduction in oil temperature. Not significant by any means, but I think safe to say it was measurable.
Ok so this was only 1 run with the Mobil against countless runs with the Mystik over the years, so at this point, based on the behavior of the oil temperature during a two hour (each way) run I have a feeling this will hold true. Time will tell, I am considering keeping the Mobil 1 in for now and further test it, who knows, MAYBE I will even run a UOA (for fun) or maybe do a second OC with it and run it the full summer.
(Ok, so here is an interesting story, I also measured the highest oil temperatures EVER, using the Mobil 1. Stuck in brutal beach traffic 3 miles before the beach, worst ever in close to ten years. Took over 35 min I think to go 1.5 miles, oil temperature even after turning on my Lenale engine fan, climbed to the low 270s. 271 for sure, possibly 274.
I was shocked the temp kept going up with the fan on, slowly, I think it was stabilizing in the low 270s, then, the engine started to stumble, stalled and restarted right away, it was at that point I said the heck with it and rode the bicycle lane into town and to the beach.
(the police officer who pulled me over when someone called them on me for riding in the bike lane was very nice, I respect police officers and treat them with respect, they have a job to do and many times a rough one at that, he ran my license and let me off with a warning after listening to my story because it was true, I thought I was breaking down)
![[Linked Image]](https://www.bobistheoilguy.com/forums/attachments/usergals/2020/06/full-50272-45971-2c7180ba_9c43_43fd_a334_9818906eb7ec_1_105_c.jpeg)
