Re 1999 Toyota Avalon with 133k miles
I am trying to identify the source of a banging noise which sounds like a lug wrench loose in the wheel well. It happens rarely with just the right combo of speed and bump. Unfortunately, one of those rare spots is 1/2 mile from my house and I hit it every time I go out. Thought it was rear lateral control arms but it is not. Stabilizer bar end links are rock solid Deeza's - only 4 years old w/20k miles. Stabilizer bar bushings were replaced a few years ago. They still look great but I have ordered new ones for kicks and giggles. Noise disappears if I remove one end link from either side. The bar is slightly worn (smaller diameter) at the bushings but does not seem enough to cause a problem. Have carried a few heavy loads of stuff in the trunk over the years but would not think that would be a big deal. Is it possible that stabilizer bars fatigue or bend over the years? I believe the noise is the stabilizer bar hitting the sub frame or somehow, with both end links in place, load transfer to the struts is causing the strut or strut mount to make the noise. Replaced original struts about 40k miles ago with KYB with Toyota OEM mounts. Thanks in advance for any ideas.
http://www.utoyot8.com/Picture.aspx?ccId=94025518&ppId=436998350&ppInfo=(9409-++++)&ccode=361410&ppName=480470C
