Originally Posted By: BrocLuno
It's not really about either miles or time - it's about heat cycles, fuel dilution, max op temp, humidity, etc. BUT, the MFG's try to make it simple and equate it to mileage and time.
You have a nice car. you need to get under, over, and around it thoroughly once a year anyway, so just change the oil while you're at it
Essentially this.
Give it a real good once over yearly and change the oil then. (Summer is much better than winter)
Essentially this.
