working on a beater 97 ram 1500 with the 318. The crossover line on the plastic fuel rail is leaking, i tried to remove it and it just fell apart, and I have no faith in replacing the crossover line and it holding.
I have read around that the fuel rails on later trucks are metal, is the crossover line at least replaceable with those fuel rails? I would use proper high pressure fuel line and clamps of course. I plan on getting one from a junkyard, I believe I'll have to get the fuel line as well because it wont fit the existing fuel rail line connectors.
