Originally Posted By: BHopkins
My only small gripe are the instructions. There are no quick instructions on how to use it, in a single sequence in the manual. You have to refer to two or three different sections of the manual to find all the steps to correctly start and stop a charge.
1. Hook up to battery.
2. Turn on charger.
3. Select voltage/battery type/charging rate
4. Press Charge to start charging.
5. Press Charge again to stop charging.
Kind of self explanatory to me. Is there more to it?
Well, if you follow the instructions from Solar, then yes.
1. Connect Pos. to battery.
2. Connect Neg.
3. Plug charger into AC.
4. Select voltage/battery type/charging rate
5. Verify no errors are displayed.
6. Press start.
7. If only charging, when "Charging Complete" light comes on, press Start/Stop button. If conditioning battery also, wait for "Charging In Progress" light to stop flashing. In this case, it is not necessary to press Stop/Start, as the charger shuts down automatically after conditioning.
8. Unplug charger from AC.
9. Disconnect Neg. clamp.
10. Disconnect Pos. clamp.
There have been a couple accounts reported here on BITOG about guys that have burned out their pro-logix charger due to a bad battery or bad connection. They determined that they had failed to follow the correct sequence at startup. So I try to be sure to follow what Solar has outlined.
