Originally Posted By: Brigadier
Nissan Titan didn't make it up with its lockers. Watch the videos unless you enjoy arguing from a position of ignorance.
I find it funny you mention ignorance.. but the titan has only a rear locker.
The powerwagon has front and rear. It also has a winch and is basically a total beast offroad.
Also conditions vary day to day. So basically unless they test 2 different tires with the same driver at pretty much the same time its not very repeatable.
And if you had any integrity and watched the videos, you would have seen that BOTH of the Titan's front wheels were spinning. BOTH, at the same time.
The Raptor got out if its trouble by using the built in winch.
So you are calling me dishonest because a titan without a front locker.... that was spinning both front tires its suddenly equal to a powerwagon?
Mods already deleted a bunch of posts in here. I suggest we stay on topic.
While the goodyear is a good tire.. those videos are worthless at proving it better than other tires. I did watch the videos. I guess no front locker = front locker now???? Next you will be telling me a regular wrangler with tires is as good as a rubicon?
