Originally Posted By: UltrafanUK
Originally Posted By: car51
So, while getting a FRAM ultra filter at Wal mart other day I heard a older man say "I always use a bottle of STP oil treatment every oil change." Dunno how good it is but I just shook my head and left as I don't believe adding additives to good motor oil will help. What do you folks say or think?
Yep, there is always at least one lunatic in every Wallymart!
STP is just an oil thickner and it makes much more sense to just use a thicker oil if that is your aim.
About 90% of oil additives either don't work or are not needed.
If you have an engine with a clearly defined issue relating to lubrication, then try looking at the Liqui Moly range of oil additives. They make a very effective flush for use at idle just before an oil & filter change (Amsoil and Castrol Classic also make similar products) and a real good anti wear additive called Ceratec that has both Moly and Boron Nitride.
Pretty much true. I have used it in the past to reduce burning in an engine on a newly acquired used car beater with a fresh oil change. And the beloved, dearly departed red bottle formula here did have lots of zinc in it making it a potentially good additive for some older cars. But other than that, it's just silly to even think of putting this stuff in a modern engine...
