Originally Posted By: KingCake
Originally Posted By: HerrStig
Originally Posted By: Donald
Originally Posted By: SubLGT
Are you still using 18V or 20V tools? What a wuss.
Dewalt has a new line of 60V tools. The batteries are actually dual voltage, at 20V/60V. They can also be paired for 120V, for the cordless table saw.
http://flexvolt.dewalt.com/en-us/
Overkill, or truly useful?
In another 10 years will we be seeing 240V cordless tools?
But it's 120v DC. A normal outlet is 120v AC.
Diodes to convert AC to DC for line operation are cheap.
You would need a bridge. There would still be ripple. It wouldn't be isolated. And you're losing lots of power due to diode forward voltage. Much better to just use an AC motor rather than 'convert'.
Diode foward voltage drop is about .7 volts generally which doesn't produce much of a drop since only two conduct at a time.
