Unrelated, but looks like that oil pan has been removed before. Was the engine sludged or did a rear main have to be replaced or something?
Kira said:3) I've always employed boards (good 2X6's) to ease jacking with a toy jack.
Do you mean like a 2 piece 4x4 of 2x6 to put ontop of the jack?
I love wood, but in this application it may not be best for the job, because of all that beautiful grain and figuring, which can lead to sudden splitting under a point load.
A heavy bidirectional laminate array of biopolymer microtubules (plywood) is safer, but I have some stainless steel rubber-backed industrial floor tiles that I use for this sort of thing.
I was thinking the same, the wood would probably split. so maybe some bidirectional laminate array of bio polymer microtubules would work well.
I use a sheet of pressboard from an old computer desk under my trolley jack to keep it from sinking into my asphalt driveway...er, I mean a heavy omnidirectional array of biopolymer microtubules in an adhesive matrix with laminated melamine reinforcement!!!
