Did my first change today on my ram 1500 I thought you all might like to see the factory filter Was very well put together no rips or tears, did its job well. 7800 miles.
Did you find any bits of metal in the filter media?
Heres a picture o the center tube,and a close-up so you can see the metal in the media. Is this filter made by purolator. And if so what is its off the shelf twin?
I believe the 2013+ 5.7L Ram calls for the Mopar MO-339, due to changes in the power steering.
My 2012 which was the last model year with a belt driven power steering pump uses the Mopar MO-899 which I understand can be used on the 2013+ models as an oversize filter option but not mfr. spec'd. for those model years.
