Well I had some time to look further into the problem. Seems to be pointing to the coil but still not 100% positive. Checked the condition of the spark when engine was stone cold. Spark looked weak. Also tested resistance of coil when cold 4.93 K ohms. Started it right up and used it for a good 1/2 hour. Shut it down and tried restarting. No deal. Checked the spark and it looked very weak. Also tested the resistance of the coil at it read 5.61 K ohms. Looked on line and B&S does not publish the resistance values of their coils. Found one guy on line who says B&S coils should read between 2.5 K ohms and 5.0 K ohms. He says that any higher than 5.0 K ohms is too much resistance and the coil is no good. The only thing I know for sure is that my test definitely indicates that when my engine is hot the resistance value of the coil is out of the range that he states. Any thoughts? Thanks all.
