Originally Posted By: KrisZ
An AC kit with its cheap gauge has its place and time. "Bring it to the professional" advice is fine and dandy when it's not you own money on the line. And the said "professionals" are not all created equal either.
Go on then, explain to me how you use the "cheap gauge" to measure a system charge on both a TXV based system and a CCOT based system.
Originally Posted By: i_hate_autofraud
In answer to the comments on half full A/C kits that fail to transfer the rest of the refrigerant, there's a fix:
When filling your A/C these kits get cold, very cold inside, that causes the pressure to drop enough that no more refrigerant transfers to the car A/C.
Yes you can warm the can. The right way to do it is with the can inverted so you are bleeding liquid in. You let the liquid flash to gas in your manifold gauge. That stops the evaporation from happening inside the can and therefore stops it getting colder with the consequential pressure drop.
