I have a manual transmission 99 Nissan Almera 1.6L, with the RS5F31A transmission which calls for GL-4 only oil, 75w-90.
I've developed a serious leak, and the gear case is almost empty. I'm going to install replacement oil seals, but the problem is that the nearest place that sells GL-4 only oil is an hour drive away.
Is there something I could use as a temporary substitute for a few days until I get a chance to drive out to the place which has the correct oil?
