I was searching around for the purpose of learning where the PCV valve is and how to check/change it. It's quite a complicated process for the Skyactiv engines. Here is a detailed look. At least it does appear that the system has a rather large and effective oil separator which SHOULD render a catch can redundant. I wouldn't call this routine maintenance at all.
Skyactiv PCV
Skyactiv PCV
