Originally Posted By: Kira
The cable operated tool which squeezes the spring clamps' ears is the best money I've ever spent.
It makes removal and installation of those clamps UNBELIEVABLY fast and smooth operations.
The one I got was from Sears...was built in France...came with a spare cable anchor (which I taped to the tool)....and cost $40. Kira
I have the same one, it's great. I have not been aggravated by a spring clamp since getting it.
Originally Posted By: Kool1
Over the years, I've occasionally gone to dealerships to replace spring loaded hose clamps and they NEVER have them in stock. I asked what they do when a spring loaded hose clamp is damaged; they replied, "we replace them with worm drive clamps".
Yeah, unfortunately if a clamp needs to be replaced at a dealer, and it's non-warranty, and the hose isn't getting replaced too...it will likely be worm drive.
I think the aftermarket and bulk suppliers really like worm drive because fewer individual part numbers cover so many more hose sizes than with the spring clamps. It's also fewer part numbers for dealers and shops to stock. Economies of scale basically. Spring clamps have been in wide use for decades now and are still harder to find readily available.
A lot of OE hoses will come with spring clamps already on them, which is another reason dealers often don't stock just the spring clamps.
I do reuse them unless there's an obvious reason not to.
