I reciently bought a 1970's radio controled toy truck.
It has a little transmission! The plastic gears are pressed onto a steel shaft with a press fit.
One of the gears is slipping on the shaft which makes the truck not move.
The O.D. of the shaft is about .035 and the same for the hole in the plastic gear. The shaft appears to be chromed.........Very slippery.
I tried super glue but it didn't hold. What can I use on these 2 parts to glue them together?
I have very limited working conditions in this transmission to work in so I can't build up the sides of the gear to get a better grip.
I was considering taking the thing to work and sand blasting the metal shaft to help the gear get a bite.
Any ideas?
Any ideas?
