Worn cam lobe symptoms
by NICAT
04/23/18 02:19 AM
White car..has white grease
by Vdubuk
04/23/18 02:17 AM
Do you need to change oil if your engine leaks
by Vdubuk
04/23/18 01:35 AM
Castrol Edge 5w30 A3/B4 SCA sale 23-24 April $29
by KL31
04/22/18 10:50 PM
Testing the "oil goes bad with age" theory
by Atomic
04/22/18 09:12 PM
08 Grand Caravan with 156k. ignition problem
by Mark72
04/22/18 09:12 PM
DexOS in a 2005 Cavalier LS?
by GMWeber
04/22/18 09:10 PM
US-Canada mail transit questions..
by earlyre
04/22/18 09:10 PM
hybrid ICE wear
by tigrpal
04/22/18 08:51 PM
03' 2.3 Ford Focus / Dash light on steadly
by Oregoonian
04/22/18 08:47 PM
Tundra vibration
by pda1122
04/22/18 08:39 PM
Who says Corvettes are gas guzzlers?
by Patman
04/22/18 08:26 PM
Mobile rebate question
by Snowball
04/22/18 08:25 PM
Oil shear and 0w,5w,10w?
by Camprunner
04/22/18 05:42 PM
Looks like the Jeep needs axle bearings
by Nick1994
04/22/18 05:13 PM
Toyota OEM Cartridge Filter, Cut Open 12,669 Miles
by Nick1994
04/22/18 04:53 PM
S/C Range Rover, 5000kms 33 different oils UOA
by Vladiator
04/22/18 04:24 PM
Buying oil on price - Pricing Rant
by JHZR2
04/22/18 04:22 PM
Mix of 33 oils VOA
by Vladiator
04/22/18 04:19 PM
Sugar Binge Hangover ... :~/
by LoneRanger
04/22/18 04:18 PM
daylateetc, Kjammer, sonnyk, PWMDMD, usernameunknown
64820 Registered Users
16 registered (Duke, FowVay, edyvw, Billbert, csandste, BlueOvalFitter, 2 invisible), 645 Guests and 51 Spiders online.
64820 Members
68 Forums
282164 Topics
Page 2 of 2 < 1 2
#4278841 - 12/19/16 02:27 AM Re: SuperTech Synthetic 5-30w, 10k, Toyota FJ 4.0L [Re: jetman]
FZ1 Offline
Loc: Texas
Silicon is too high. Buy a new Toyota air filter every 2 years or 15,000 miles.
#4279364 - 12/19/16 05:24 PM Re: SuperTech Synthetic 5-30w, 10k, Toyota FJ 4.0L [Re: FlyNavyP3]
veryHeavy Offline
Loc: MN, CA
Originally Posted By: FlyNavyP3
Originally Posted By: veryHeavy
Go back to the stock air filter.... but go with a quality brand (not Toyota). Your silicon levels will drop dramatically, because paper filters stop dirt better than oiled foam
I've always had exceptionally low Si levels with OE Toyota air filters. Not sure what the basis for not recommending a Toyota OE filter here is.
I have seen various tests that show Toyota/Honda air filters allow a lot of dirt to pass (25-50% at 20u). Name-brand filters (if they are paper) only allow 1-5% to passthru filtration levels. I have AC Delco on my Honda and the Si level is almost zero.
In any case, stay away from the oiled foam.
They don't do well at all.
#4290324 - 01/01/17 09:42 AM Re: SuperTech Synthetic 5-30w, 10k, Toyota FJ 4.0L [Re: dave1251]
The_Cams Offline
Loc: TX
Walmart uses different suppliers for their Super Tech products based on bids. If you search the UPC of the product it will reveal the MSDS of the current provider(s): http://msds.walmartstores.com You can't simply search by name, because it lists old suppliers. Has to be UPC to list current supplier(s).
The last time I searched the Super Tech Syn oil UPC it revealed 2 providers, probably distributed by region. One was Warren Distribution and the other was Citgo.
#4290757 - 01/01/17 08:20 PM Re: SuperTech Synthetic 5-30w, 10k, Toyota FJ 4.0L [Re: jetman]
HerrStig Offline
Loc: Boston, MA
So, Honda and Toyota make good quality cars and trucks but provide low quality oil and air filters for them? Yup, that makes a LOT of sense to me. I hear Yugo filters are GREAT.
BTW 2000 miles ago I changed my Gen 4, I4 Camry oil to the WPP version of Supertech 5 w 30 synthetic....the engine has 215,000 miles on it and hasn't burned a drop that I can see.
Edited by HerrStig (01/01/17 08:25 PM)
#4291239 - 01/02/17 12:14 PM Re: SuperTech Synthetic 5-30w, 10k, Toyota FJ 4.0L [Re: The_Cams]
GMFan Offline
Loc: NC
I have no evidence that different suppliers supply different weights of SuperTech Synthetic, but I have confirmed in the past with VOAs that SuperTech 5w30 Synthetic is identical to Accel Synthetic 5w30 which is made by WPP. The oil may also be identical or similar to Mag1 made by WPP. It is widely believed here that WPP provides all Supertech Synthetic and it is only the conventional Supertech that is spread among multiple suppliers (as evidenced by different bottles in different parts of the country).
https://pqiablog.com/2015-motor-oil-samples-tested/
If you compare 5w30 Supertech Synthetic with Accel 5w30 Synthetic they are identical products.
Edited by GMFan (01/02/17 12:16 PM)
2011 Mazda6, 110k miles
Valvoline Maxlife 5W20, Napa ProSelect
“Muscles aching to work, minds aching to create - this is man.”
#4291669 - 01/02/17 09:07 PM Re: SuperTech Synthetic 5-30w, 10k, Toyota FJ 4.0L [Re: veryHeavy]
kschachn Offline
Loc: Upper Midwest
You've seen tests on Honda and Toyota air filters? Where?
1994 BMW 530i, 225K
1996 Honda Accord, 268K
1999 Toyota Sienna, 389K
2000 Toyota ECHO, 265K
#4311251 - 01/24/17 11:45 AM Re: SuperTech Synthetic 5-30w, 10k, Toyota FJ 4.0L [Re: HerrStig]
veryHeavy Offline
Loc: MN, CA
Honda and Toyota have had major recalls (or lawsuits) about various engines (and also transmissions in Honda's case). They are not perfect. Anyway I don't think it's worth debating. If the OP is using an "oiled foam" filter then he will see the silicon/dirt levels drop by switching back to a paper filter, like Toyota originally supplied with the car.
#4400875 - 05/10/17 09:12 AM Re: SuperTech Synthetic 5-30w, 10k, Toyota FJ 4.0L [Re: GMFan]
The_Cams Offline
Loc: TX
@GMFan,
Again, go to Wal-Mart, take the UPC off the bottle, go to the website, plug it in, click submit and you'll get the suppliers listed on the MSDS(s). http://msds.walmartstores.com That's your evidence. It doesn't get any clearer. Then you have to figure out which supplier services your area. In my area it's Citgo. Searching by name doesn't provide sufficient answers because it brings up MSDS's from previous inactive suppliers. The UPC off the bottle on the shelf reveals current supplier information.
You can do the same for ST brake fluid, transmission fluid, etc.
Edited by The_Cams (05/10/17 09:16 AM)
#4401344 - 05/10/17 06:47 PM Re: SuperTech Synthetic 5-30w, 10k, Toyota FJ 4.0L [Re: jetman]
FlyPenFly Offline
Loc: San Diego
There could also just be a rip in your intake somewhere or maybe a vacuum leak somewhere that's sucking in dust.
2014 Mercedes GLK350 3.5L DFI
2014 Mercedes E350 Coupe 3.5L DFI
#4406122 - 05/16/17 11:36 AM Re: SuperTech Synthetic 5-30w, 10k, Toyota FJ 4.0L [Re: jetman]
Hootbro Offline
Loc: DELAWARE
I think you got your moneys worth out of the SuperTech Synthetic. Just the margins are low for people who run it way past 10K it would seem but I really do not fault it for that.
2018 Jeep Wrangler JL 3.6L (Idemitsu 0W-20)
2017 Jeep Renegade 2.4L (Idemitsu 0W-20)
#4406217 - 05/16/17 01:34 PM Re: SuperTech Synthetic 5-30w, 10k, Toyota FJ 4.0L [Re: GMFan]
Virtus_Probi Offline
Loc: New England
The Accel and Supertech 5W30s on that page do look quite similar by the VOAs, but they appear to be conventional oils. The Accel is not labelled either way, but the Supertech says conventional on the bottle.
Am I missing something?
2014 Forester XT, 80500 miles
Last Change;
Valvoline Full Synthetic 5W30 d1G2
Tokyo Roki 15208AA170 filter
#4406232 - 05/16/17 01:53 PM Re: SuperTech Synthetic 5-30w, 10k, Toyota FJ 4.0L [Re: jetman]
WobblyElvis Online   content
Loc: Toronto Canada
IMO tbn numbers don't mean much. I've had Blackstone recommend I go further when the tbn was already down to 1.0. Just a couple of days ago there was a post here on BTOG about how unreliable tbn tests were. I look more at the wear numbers and the viscocity. I'd take this oil out another 2,000 miles without concern.
#4406273 - 05/16/17 02:49 PM Re: SuperTech Synthetic 5-30w, 10k, Toyota FJ 4.0L [Re: WobblyElvis]
CharlieBauer Offline
Loc: CA
Blackstone are the only people who make that kind of recommendation. PQIA feel that oil should be changed when TBN is 3 and all other oil labs are in that same range.
I agree that viscosity is important because rising viscosity means the oil is oxidizing. Remember that the oil shears first before it thickens. In this case, a KV100c of 10.2 is not because Supertech is shear stable, it is probably because it is now thickening after shearing.
At this point in an extended oci, another 2000 miles is the kind of interval where an oil can rapidly degrade. I wouldn't say it's definite, not even likely to cause any problems. But I'd want to avoid any chance of deposits forming and agree with the OP about changing it out.
It ain't what you don't know that gets you into trouble. It's what you know for sure that ain't so.
- mistakenly attributed to Mark Twain
Page 2 of 2 < 1 2
