The main difference between the add-in-tank type carb cleaner vs fuel injector cleaner is that carb cleaner focuses on dissolving gums inside the carb jets and orifices; PEA-based fuel injector cleaner "dissolves carbon/deposits" that formed near or surrounding the pintle (I know nowadays most P-EFI injectors are pintle-less, but the 2ndary benefit of PEA-based FI cleaner can help in gradually (catchword: gradually, not rapidly) softens and breaks down the carbon formed at the back of intake valves, which, ordinary carb cleaner usually cannot (most carb cleaners I'm aware of are meant for carb days where most of them are primarily solvent-based.
Different intended purpose.
Q.
BTW: emisssions-controlled automobiles no longer run on carbs, and are all primarily fuel-injection based.
