Quote:
Times have changed. It has been proven over 10 years in Iraq/Afghanistan that the AR platform guns run much better dripping wet in oil.
Actually they have not. The Army published a recommendation on using extra lubrication for extremely dusty environments based on testing and only at the extremes did those tests demonstrate that running the M16's and the M4's wet improved reliability of the BCG cycling. As with all things there is a compromise and with running an AR dripping wet you introduce lubricant into the chamber which has proven to cause bolt thrust forces to more than double. That's basically were the "reliability" comes in but that also means the bolt and related parts are subject to increased wear and possibility of failure. Running an AR "wet" is not a sound practice and decades of research back that up.
