Nick1994
$100 site donor 2024
So on my mom's 2003 Buick Rendezvous AWD it's been having an issue with the headlights. The passenger side headlight is nice and bright but the drivers side is very dim. Also, the high beams are on with the low beams but are super dim and the fog lights are on and dim too. There's supposed to be no way for all of those to be on together, and the left front turn signal doesn't work right, it sort of flashes but also flashes the brights and low beam? Also on the instrument cluster the left arrow indicating the turn signal is stuck on and dim. Also occasionally there's a message on the display that says "Service Vehicle Soon" - NOT service engine soon, that's different. The service vehicle soon I've Googled and usually has to do with lighting issues. Sometimes if I smack the bumper or hood with my hand it fixes itself and the low beam is nice and bright and the other lights go out. I swapped the low beam bulbs and it didn't make a difference. I checked all headlight and fog light connections and they're nice and tight. I'm assuming it's a ground issue but I can't find any ground connections. Is it possessed or has anybody experienced something like this?
Thanks
Thanks
