Hail Bitog, full of grease, the lard is with thee.
So, for those of you with a somewhat long memory, you might recall that way back the early spring of 2013, the ever faithful "Bluesmobile" was giving me some tranny fits.
I flushed the fluid, changing both fluid and filter and then cycling some 16 quarts of new fluid through the old tranny. After some fits and sputters, I added a variety of additives and finally achieved motoring happiness which has continued ever since.
For the sake of recollection, the unholy brew included -
2 bottles Lucas transmission fix
1 bottle of Lubegard Platinum (silver bottle, I thought it was "the best" but found out later it was for Chrysler applications).
1 bottle Lubegard red
1 bottle Seafoam transfix.
The Seafoam actually did the job as within about two miles of addition, the ever faithful "Bluesmobile" was running like she did when she left Detroit.
That was almost two years and about 10,000 miles ago, (maybe 12,000).
Now, on the one hand, I am firmly in the "if it ain't broke" crowd. Said "Bluesmobile" continues to run well with tranny happily transmitting power from the motor to the wheels.
On the other hand, I've got a hankering to do a fluid change like I did before. While I won't change the filter, I can pump out the fluid via the filler tube with a hand pump and cycle another 16 quarts of fresh fluid through the transmission, this time, maybe going light on the additives.
I know when I did it two years ago, the fluid that came out was coffee black, and I'm thinking over the past two years, said new fluid has done a cleaning job, (along with the Seafoam which claims to clean - which, btw, I believe it did). So, I'm thinking of going fresh with the hopes of extending transmission happiness for many miles to come.
What say you guys.
Said vehicle is a 1993 Ford Taurus with the 3.0 V-6 and ORIGINAL transmission with 163,000 miles on the clock.
Thoughts, opinions, ideas?
What say you guys.
