Hello everyone, I am unfamiliar with hydraulic clutch systems and I want to ask you guys some questions.
Do you change the fluid of the clutch when you change the brake fluid?
Do you change it at the same interval?
If you don't change it, does this old fluid contaminate the new one? Since they share the same reservoir.
Does a pressure bleeder also works on the clutch? Meaning I just open the bleed screw until new fluid comes out, or there is another step I'm missing?
And do you bleed the clutch after or before the brakes?
Thanks in advance for all your help,
