Dodge Durango 8HP45 transmission filter change - pictures
One of these would probably work too.
That’s just a 1/4“ hex torx bit in a 1/4” female universal socket. And held in somehow….
Yes and no. It’s more compact. Swaged together. A purpose built, compact tool. No worries of having the bit fall out while trying to work and shorter than a bit in a socket.
And available in T40.
Their universal sockets are compact, very useful for tight quarters work.
I haven’t found anything more compact than these:
That’s a nice tool, and I like that it plugs right into an impact.
However, it’s six inches long with limited articulation. It also has a large head.
There are places on my Mercedes where that will not fit, due to the limited articulation, and large head.
But the 1/4” drive universal socket will fit, because of the very small head and good articulation of the universal. Can’t use a driver in a space that small anyway.
It’s up to Wayne to choose what works for him. And simply getting around the one frame rail might make your suggestion a better choice for him.
I think each tool can potentially serve a different purpose. I don't think one option is necessarily "better" than the other. However...
The "joint" style universals may have a greater range of motion (compared to the ball style), but they are not very usable at extreme angles anyway. For this reason, I personally find the ball style universals to be more practical.
Most likely from machining, They look Aluminum? 8HP's have a ton of Aluminum parts in them plus the Case itself.....So a few stray machining chips is to be expected. No concern!
Yes, I would say they look aluminum.
Thanks for the response!
I have a 2021 WK, and they removed the drain plug on the teans pan on this model year. So I'll have to do a transfer pan replacement when I do a fuild drain.
Sorry to revive an old thread but how do you go about doing this “spill and fill” on the Durango? I have an 18 R/T with 60k miles. I was thinking of doing this method for some cheap preventative maintenance
You basically disconnect the cooler return line, put a length of clear, vinyl tubing on it, put the other end into an oil container, start the engine in park and let the transmission pump out the ATF. You will probably get close to a gallon before you see bubbles, then you shut the engine off and top off the ATF. I do it until I see clear ATF flowing through the tube, which is around the total ATF capacity of the transmission.
Here is how I did it on my Grand Caravan. In my case the lines are super easy to access on the transmission. Not sure how the access looks like on your Durango.
https://bobistheoilguy.com/forums/threads/2015-grand-caravan-super-easy-atf-exhchange.275419/.
My understanding is this dosent work with the 8HP75 do to it has a thermostatically controlled cooler?
The original OEM pan had a drain plug, today the OEM pans don't. You either need to put a plug into the pan, remove the pan for each spill and fill, or buy an aftermarket pan like a PPE that has a drain plug.
****... was afraid of that because ive never seen a drain plug on mine, was hopeful there was something i was missing lol
