Originally Posted By: kschachn
See, that's actually the problem. I do have a BSME with a minor in chemistry. I also worked for the chairman of the chemistry department for all four years as a lab tech doing assorted grunt work, including teaching a lab on fuels and lubricants.
That's why when I see statements like this it's like a red cape to a bull. I can't help but charge.
You have said some doozies in this thread, but that has to take the cake.
Do any of you ever consider that if the energy is more efficiently converted its possible to obtain equal mileage to gas? More complete combustion equals less wasted energy.
If you had any engineering or technical background at all, you would understand. That goes for clevy too. I don't know how to take this stuff down to 3rd grade level.
You don't understand that for a gallon of gasoline some percentage is converted to work, and the rest is waste in the form of incomplete combustion, waste heat, friction, etc? You can't as easily lean gas out to 20/1 or more to get a more efficient burn and resulting more complete conversion of gasoline to energy. A fuel like ethanol might be able to burn much leaner thus converting more of the product to energy. I envision a lean burn mode kicking in when the cruise control is on or something similar.
example
1 gal gas = x btu
1 gal ethanol = .7x btu
if gas conversion is 60% we have .6 btu work
if ethanol conversion is 90$ we have .9*.7 btu = .63 btu
do you understand where I'm headed with this?
example
1 gal gas = x btu
