Originally Posted By: Shannow
Originally Posted By: SteveSRT8
There was a significant study done by Ford that showed ring wear went up as cylinder wall temp went down. In my limited recall there was ZERO mention of oil in any way as a factor. Logically there is some sort of effect from viscosity but it should be obvious that thick oil doesn't automatically kill engines.
from my experiences with Holden engines in particular, the front cylinders have the highest lip at the top of the bores. As the coolant heads to the back of the engine, it's warmer, cylinders are warmer, and here's less lip...in the area of the cylinder lubricated boundary/mixed, not the hydrodynamic area that is in the centre of the stroke.
Had one engine that I bought that had had the thermostat removed for ages, at least two owners (caught up with the original, thermostat out guy in a car park), and the bores were heavily lipped, and valve guides badly worn, to the point of visible ovality...again, boundary lubed areas.
Convinced me that control of temperatures are required for proper lubrication...and inlet control thermostats
http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3305744/Re:_Inlet_side_thermostat_inst#Post3305744
See the sequence IV testing for more detail on what API and the automotive industry thinks causes wear.
That effect is interesting. One would think that given the modes of lubrication at various parts of the bore, that additive efficacy is critical to consistent wear performance? Which Holden engine was it? Iron block I'm assuming, curious about the nickel content of it.
Also, outlet thermostats are a superior design
Originally Posted By: Clevy
I've already saved my notes on the liqui-moly so now
You know Clev, that observed reduction of bulk oil temp with the Lubro-Moly had me thinking, could it be that they use their Ceratec FM additive in it in the stock formula?
