The 92-96 Camry and ES300 specify tire pressure of 26 psi up to 4 passengers, and 32 psi when loaded up to the GWVR. That seems awfully low for a fairly heavy car. The stock tire size is 205/65VR15.
Mine are inflated to 32 psi, and all the tire shops around here, from Walmart all the way down to your local joint, use 32 psi as the reference.
