Originally Posted By: supton
Sounds like you want the LTX MS2 but in 18" size. Per your words, the roads are clear the day after, and most of your driving is done on dry roads. A fresh set with full tread is going to do better than your worn tires. Not as good as snows, but if it's a tire tread that does the job...
What about waiting until after the first snow or two, and then making a decision? As in, if the current tires do ok in the slush, perhaps just get another set for the winter rims at that time? Or, if they just aren't aggressive enough, then bring this topic back up?
I would love to do that but I'm trying to get the tires before the rebates expire (10/27 and 11/5 iirc).
That and I don't want to be in a crunch if we do happen to get a lot of snow but ideally that's what I would like to do.
