Originally Posted By: CapriRacer
Originally Posted By: volk06
Did you already create a post about these tires a day ago?
http://www.bobistheoilguy.com/forums/ubb...659#Post3157659
Anyway, it is very odd to have that many tires not seat on the bead. I'm curious if it was just something to do with the people installing them or something.
That would be my vote. Unless there is some other sort of problem, 90 psi should have seated pretty much ANY passenger car tire.
I suspect they didn't apply enough lube.
i saw them do it after the first one they used tons of lube. Almost a ridiculous amount. Looked like enough lube that you could have some very buttery popcorn . It was A LOT. I did message them this evening. Expressing my concerns. Mainly on safety.
Honestly, this makes no sense.
First, the beads are molded so not only would ALL these tires have the same problem - 10's of thousands ought to have the same problem. That's just beyond reason.
Did they apply the lube to the rim BEFORE they tried to seat the tire? Applying the lube AFTER the bead has hung up is useless. The lube needs to be between the surfaces.
im not sure what doesnt make sense, we tried 3 new sets plus my one set I had bought none worked correctly and they all had the same issue. Yes they lubed it well before the tried to get it on. I have personally installed my fair share of tires and these tires were defective. If they were doing it wrong wouldnt they have issues with the sumic that installed perfectly?
Is there a special dance and hat trick we should have tried to get coopers to seat correctly? As far as I know the job isnt that complicated and generally speaking its the same for most tires.
Not to sound rude but some people try to over think things. 4 sets didnt work. But 1 set of a different brand of tire worked perfectly and the conclusion some people come up with is "they did it wrong" those deductive reasoning skills do not make sense. The tires were flawed. Simple conclusion.
