Just changer the gear oil in my sterling 10.25 12 bolt. While had the cover off I was looking around in there and noticed some decent wear on the spider gears (open diff). I could rotate the pinion left and right maybe 1/8 to 1/4 inch and visibly observe the spider gears move as the slack was taken up engaging the shaft gears.
This unit is supposedly a reliable diff, but with 174k on it and unknown previous maintenance on it I am wondering how long I have on it before a rebuild or maybe a upgrade to a locker or something is necessary? Ring gear still has a centered wear pattern but it does reach most of the surface toward the toe and heel. Maybe 1/2 inch left on each end.
I have just moved to syn 75w-140 from syn 75w90 thinking this could cushion the spiders enough to prolong it's life. Good idea? Thanks.
