Hi,
Looking to get as much info overnight regarding the known issues with transmissions in this model. To start out with:
a. Are there certain years within that timeframe that are more problematic than others?
b. It sounds like the v6 was more problematic than the 4cylinder -- correct?
c. What exactly was the most common issue with transmission failures?
d. Were the transmissions typically failing around 100k?
Anything else you can add, is deeply appreciated. In a bind, and need to move quickly on a vehicle.
Along these lines, was the previous model (94-97) mostly trouble free?
Thank you very much.
