I have 168k miles on my 2001 Ford Ranger XLT 2.5L.
Coolant has never been changed. I think some might have been added at one point. Coolant looks dark green. Not sure what color it's supposed to be (bright green?). Engine runs good. Not sure if a flush at this point is ok to do. Should I just ask for a drain and fill, or is a flush ok? Should I go to my normal shop or will the dealer do a better flush since they're used to dealing with Fords.
What kind of coolant do you guys normally use? I guess I could buy some and tell the shop to do it.
I also have to get a new timing belt sooner rather than later since I'm on my original. Is changing or dumping fluid a part of changing the timing belt when they take everything apart? I don't want to get my fluid changed now, and then in 4 months when I decide to get a new timing belt, have to pay to do it all over again.
I have no issues with heating or cooling. I live in NY, so I've driven it this past hot summer without any issues, and so far this winter without any issues. The shop I go to said I don't need to change it yet. It's still a little dark, and I'd prefer to start fresh.
I also read that the coolant might turn brown if I get it flushed.
