I recently had two cars at America's Tire for a routine tire rotation/balance.
I observed that the techs will not rebalance the tire if the balancer only shows 0.25 oz of weight needed, and will deem the tire acceptable. According to their techs, a tire that needs 0.25oz of weight should not display any vibration issues.
In both instances that I observed this practice, they were using a balancer that utilized the Hunter Smartweight software. When the balancer showed that 0.25oz was needed, it displayed that the static force to be exceeding the pre-determined threshold.
Now, I have noticed some slight steering wheel vibration at higher speeds in both cars where this balancing procedure was used, but it's not significant enough where I could truly say that it is a balancing issue.
In the past, the America's Tire shops have always balanced the tires for me until the balancer said that the tires are balanced completely, but apparently this has changed.
Thoughts on this matter? CapriRacer? Has anyone else experienced this?
Thx.
Thx.
