Starting a new thread as advised in relation to my Pathfinder
The oil that in there is Carlube 5w30 Fully Synthetic Longlife
This is a quote from the website and I can find no specs other than this.
"Carlube 5w30 Fully Synthetic Longlife oil is a high specification oil designed to meet the ever increasing demand for a quality yet affordable 5w30 fully synthetic oil. Suitable for high performance, higher mileage petrol and diesel engines on extended (longlife) service intervals.
Specifications: API SM/CF, ACEA C3"
From the info on the bottle it is a Low saps/Low ash oil to API SL and ILSAC GF-3.
It is made by Tetrosyl, a UK based company.
I now have 7k miles on this oil with a Nissan filter, there has been zero oil usage so far. Car has a DPF and the oil has no smell of diesel.
I was thinking about changing the oil at this point with Castrol Edge 5w30 C3, C3 being an ACEA spec for DPF equipped diesels. And doing a UOA on the Carlube.
But after some consideration I think this would be wasteful as this is an oil that meets C3 specs so even though the name isn't one of the big names perhaps I am not giving it enough of a chance.
I am now considering an adjusted plan of action.
1. To let it run up to a nice even 10k miles, doing UOA, then changing it out.
or
2. Taking a sample for UOA now at or near 7k miles and then leaving the oil in situ till 10k miles and then changing it out with a further UOA.
Oil going in will almost certainly be Castrol Edge FST 5w30 C3.
I believe that this plan will maximise usage of the current oil and give a better baseline for further use.
Any comments welcome.
If you have any other ideas about the next oil to use then I would glad to hear it.
My main criteria for the next oil is that I can get Edge FST C3 for under £30 for 4 litres, meaning the quantity needed is just under £60. 2x5 litres of the Carlube oil was £72, ok I got another 2 litres but I think Castrol Edge will be a better oil.
or
