Here is the dilemma, I have a Corolla XRS with the Aisin C64 6-Speed Trans. My manual states that I can use 75W90 GL-4/GL-5 oil in it.
After many hours of research I decided to stick with GL-4. I simply do not trust Manuals or dual rated oils. Manufactures simply do not look out for the consumers only the bottom line. you cn thank Wall Street for that!
I am running 75W90 Motorcraft XT-M5-QS. Made Germany , but it is pricy. Castrol Syntorq LT 75W-85W GL-4 (GM# 12346190)is also a sub but is super pricy and thinner that what the book calls for?
I do know that there are 75W85 GL-4 oil that I can use that are half the price! The oil I am considering is the off the shelf Nissan OEM Manual Transmission Fluid MTF 75W85 For half the price. Do you think I would be fine with the 75W85?
