This is for audio conf purposes (like Skype).
Say you want two people on the same end of a laptop to be able to listen as well as talk, but not using the built-in speakers and built-in mic due to poor audio quality issues.
Can I just use two headsets connected to the laptop using two splitters (one for headphones and one for mic)? I know it'll work fine for the listening part, I'm just not sure about the speaking part. If the two people are sitting fairly close to each other, won't the two mics interfere with each other?
I guess I should just try it and see, unless you guys have other fairly inexpensive ideas.
I've got two of these and two of these on the way.
